Updated on 2025-11-24 GMT+08:00
Task Management
You can view tasks in the task list, which shows policy-driven tasks that have been executed over the past 30 days.
There is at least one task.
Viewing a Task
  1. Log in to the CBR console.
    2. Click in the upper left corner and select a region.
    3. Choose Storage > Cloud Backup and Recovery > Tasks.
  2. Filter tasks by task type, task status, task ID, resource ID, resource name, vault ID, vault name, or time.
  3. Click in front of the task to view the task details.
    If a task fails, you can view the failure cause in the task details.
