Modifying a Policy
You can modify existing policies if needed.
At least one policy has been created.
- Log in to the CBR console.
- In the upper left corner, click
and select a region. - Click
and choose Storage > Cloud Backup and Recovery.
- Locate the target vault and click the vault name to view its details.
- In the Policy area, click Edit in the row of the policy to be edited.
- Click OK. You can view the rules column of the new policy in the policy list.
The new retention rule may not apply to existing backups. For details, see Why Isn't the New Retention Rule Being Applied?
Alternatively, select Policies from the navigation pane and edit the desired policy.
