Updated on 2025-11-24 GMT+08:00
Replicating a Vault Across Regions
Cloud server backup vaults allow you to replicate all backups in vaults to replication vaults of the same account in another region. Replicas of server backups in the destination region can be used to create images and provision servers. to quickly deploy services across regions.
There are two methods available for replicating a vault.
  • Manual replication: Select a backup vault and manually replicate it.
  • Policy-based replication: Configure a replication policy to periodically replicate backups that have not been replicated or failed to be replicated to the destination region.
  • Disk backup vaults cannot be replicated to other regions.
  • Backups can be replicated to vaults in different regions. Any traffic costs associated with this operation will be attributed to the source region. Backup replicas take up the replication vault space.
  • A server backup vault can be replicated only when it contains at least one backup that meets all the following conditions:
    1. It is an ECS backup.
    2. It contains system disk data.
    3. It is in the Available state.
  • Only backup vaults of the same type can be replicated. Replicated vaults cannot be replicated again but their replicas can be used to create images.
  • A backup vault can be replicated to different destination regions. For manual and policy-based vault replication, a vault can only be replicated to a destination region once. It cannot be replicated to that region again, even if its backups have been deleted.
  • Only replication-supported regions can be selected as destination regions.
  1. Log in to the CBR console.
    2. In the upper left corner, click and select a region.
    3. Click and choose Storage > Cloud Backup and Recovery.
  2. On the Vaults tab, find the target backup vault.
  3. Choose More > Create Replica in the Operation column of the vault.
  4. In the displayed dialog box, configure the parameters as described in Table 1.
    Table 1 Parameter description
    Destination Region
    Region to which the vault is replicated
    Only the regions that support replication will be displayed.
    • If the selected region contains only one project, you can directly select the region name.
    • If the selected region has multiple projects, the default project of the region is preselected. You can select another project if needed.
    Destination Vault
    A replication vault in the destination region.
  5. Click OK.
  6. After the replication is complete, you can switch to the destination region to view generated replicas. For details, see Viewing a Vault. You can then use replicas to create images.
