Updated on 2025-11-24 GMT+08:00
Changing Vault Specifications
Server backup vaults and replication vaults both have two specifications: those for common server backups and those for database backups.
  • Common server backups are backups of non-database servers.
  • Database server backups are backups of database servers.
If you need to back up database servers, change the specifications of the target vault from server backup to application-consistent backup.
You can only change the specifications of a vault from server backup to application-consistent backup, but not the other way around.
  1. Log in to the CBR console.
    2. In the upper left corner, click and select a region.
    3. Click and choose Storage > Cloud Backup and Recovery.
  2. On the Cloud Server Backups page, find the target vault. Choose More > Change Specifications in the Operation column of the vault.
  3. Application-Consistent Backup is preset for Backup Type. Click Next.
  4. Click Submit and complete the payment. The system automatically changes the vault specifications.
    After the change, the vault specifications in the vault list are changed from Server backup to Application-consistent backup.
