Updated on 2025-11-24 GMT+08:00
Dissociating Resources from a Vault
If you no longer need to back up an associated resource, dissociate it from your vault.
After a resource is dissociated from a vault, the vault's backup or replication policy no longer applies to the resource. In addition, all manual and automatic backups of this resource will be deleted. Deleted backups cannot be used to restore data.
Dissociating a resource from a vault does not affect the performance of services on the resource.
  1. Log in to the CBR console.
    2. In the upper left corner, click and select a region.
    3. Click and choose Storage > Cloud Backup and Recovery.
  2. Locate the target vault and click its name.
  3. In this example, cloud servers will be used as an example to illustrate the process. Click the Associated Servers tab. Find the target server and click Dissociate in the Operation column.
  4. Confirm the information and click OK.
    After the disassociation, the result is displayed in the upper right corner. If the target server is not displayed in the Associated Servers list, the disassociation is successful.
