Updated on 2025-11-24 GMT+08:00
Viewing a Vault
You can set search criteria for querying desired vaults in the vault list.
A vault has been created.
Viewing Vault Details
  1. Log in to the CBR console.
    2. In the upper left corner, click and select a region.
    3. Click and choose Storage > Cloud Backup and Recovery.
  2. On the Vaults tab, view basic information about all vaults. Related parameters are described in the following table.
    Table 1 Basic information parameters
    Name/ID
    Name and ID of the vault. Click the vault name to view details about the vault.
    Type
    Vault type, which can be backup vault or replication vault.
    • A backup vault stores backups of servers and disks.
    • A replication vault stores replicas of backups.
    Status
    Vault status. Table 2 describes the vault statuses.
    Specifications
    Vault specifications, which can be server backup or application-consistent backup.
    • A server backup vault stores backups of non-database servers.
    • A database server backup vault stores backups of database servers.
    Vault Capacity (GB)
    Capacity used by the backups in the vault. It shows the space used by backups and the total vault capacity.
    For example: If 20/100 is displayed, 20 GB has been used out of the 100 GB vault capacity.
    Associated Servers/File Systems/Disks
    Number of servers, file systems, and disks associated with the vault. You can click the number to view details of associated resources. The associated capacity shown on the details page is the total capacity of all the resources that have been associated with this vault. If an associated resource is deleted, the resource is still counted in the number of associated resources.
  3. On the Vaults tab, set filter criteria to view specific vaults.
    • Select a value from the status drop-down list to query vaults by status. Table 2 describes the vault statuses.
      Table 2 Vault statuses
      Status
      Attribute
      All statuses
      All vaults are displayed if this value is selected.
      Available
      A stable state
      A stable state after a vault task is complete.
      This state allows most of the operations.
      Locked
      An intermediate state
      An intermediate state displayed when a capacity expansion is in progress.
      If a vault is in this state, you can perform operations, such as applying a policy and associating servers, file systems, or disks. However, the following operations are not allowed on such a vault: expanding the vault capacity and changing the vault specifications. Once those operations are complete, the vault status will become Available.
      Deleting
      An intermediate state displayed when a vault is being deleted.
      In this state, a progress bar is displayed indicating the deletion progress. If the progress bar remains unchanged for an extended time, an exception has occurred. Contact technical support.
      Error
      A stable state
      A vault enters the Error state when an exception occurs during task execution.
      You can click Tasks in the navigation pane to view the error cause. If the error persists, contact technical support.
    • Search a vault by its name or ID.
  4. Click the name of a specific vault to view vault details.
    • The values of used capacity and backup space are rounded off to integers. CBR will display 0 GB for any backup space less than 1 GB. For example, there may be 200 MB backup space used, but it will be displayed as 0 GB on the console.
