x-apigateway-backend.parameters
Meaning: API backend service definition.
Scope of effect: x-apigateway-backend
Example:
paths:
  '/users/{userId}':
    get:
      produces:
        - "application/json"
      parameters:
        - name: "X-Auth-Token"
          description: "Authentication token"
          type: "string"
          in: "header"
          required: true
        - name: "userId"
          description: "Username"
          type: "string"
          in: "path"
          required: true
      responses:
        default:
          description: "default response"
      x-apigateway-request-type: "public"
      x-apigateway-backend:
        type: "HTTP"
        parameters:
          - name: "userId"
            value: "userId"
            in: "query"
            origin: "REQUEST"
          - name: "X-Invoke-User"
            value: "apigateway"
            in: "header"
            origin: "CONSTANT"
          description: "Caller"
       Parameter  |
       Mandatory  |
       Type  |
       Description  |
       name  |
       Yes  |
       String  |
       Parameter name, which consists of a maximum of 32 bytes, starting with a letter. Only letters, digits, periods (.), hyphens (-), and underscores (_) are allowed. The names of header parameters are not case-sensitive.  |
       value  |
       Yes  |
       String  |
       Parameter value, which is a parameter name if the parameter comes from a request.  |
       in  |
       Yes  |
       String  |
       Parameter location, which can be header, query, or path.  |
       origin  |
       Yes  |
       String  |
       Parameter mapping source. The options include REQUEST and CONSTANT.  |
       description  |
       No  |
       String  |
       Parameter meaning.  |
