Help Center/
      API Gateway/
        Dedicated API Gateway User Guide (Paris Region)/
        API Management/
        Importing and Exorting APIs/
        Extended Definition/
      x-apigateway-match-mode
        Updated on 2023-12-20 GMT+08:00
Meaning: Request URL matching mode, which can be NORMAL or SWA.
Scope of effect: Operation Object (2.0)
Example:
paths:
  '/path':
    get:
      x-apigateway-match-mode: 'SWA'
       Parameter  |
       Mandatory  |
       Type  |
       Description  |
       x-apigateway-match-mode  |
       Yes  |
       String  |
       API matching mode. The options include SWA and NORMAL.
   Parent topic: Extended Definition
