Signature Keys
Updated on 2023-12-20 GMT+08:00
Signature keys are used by backend services to verify the identity of APIG.
A signature key consists of a key and secret, and can be used only after being bound to an API. When an API bound with a signature key is called, APIG adds signature details to the API request. The backend service of the API signs the request in the same way, and verifies the identity of APIG by checking whether the signature is consistent with that in the Authorization header sent by APIG.
Usage Guidelines
An API can only be bound with one signature key in a given environment, but each signature key can be bound to multiple APIs.
Figure 1 Signature key process flow
  1. Create a signature key on the APIG console.
  2. Bind the signature key to an API.
  3. APIG sends signed requests containing a signature in the Authorization header to the backend service. The backend service can use different programming languages (Java, Go, Python, JavaScript, C#, PHP, C++, and C) to sign each request, and check whether the two signatures are consistent.
Configuration Parameters
Table 1 Parameter description
Name
Signature key name.
Type
Authentication type. Options: HMAC, Basic auth, AES.
Signature Algorithm
Select an AES signature algorithm. Options:
  • aes-128-cfb
  • aes-256-cfb
Key
Set the key based on the signature key type you have selected.
  • If Type is HMAC, enter the key of the key pair used for app authentication.
  • If Type is Basic auth, enter the username used for basic authentication.
  • If Type is set to AES, enter the key used for AES authentication.
  • If Type is Public key, enter the public key used for authentication.
Secret
Enter the secret information based on the key type you have selected.
  • If Type is HMAC, enter the secret of the key pair used for app authentication.
  • If Type is Basic auth, enter the password used for basic authentication.
  • If Type is set to AES, enter the vector used for AES authentication.
  • If Type is Public key, enter the private key used for authentication.
Confirm Secret
Enter the secret again.
Verifying the Signing Result
Sign each backend request by following the instructions in section "Creating Signatures for Backend Requests" in the API Gateway Developer Guide, and check whether the backend signature is consistent with the signature in the Authorization header of the API request.
