CORS
For security purposes, the browser restricts cross-domain requests from being initiated from a page script. In this case, the page can access only the resources from the current domain. CORS allows the browser to send XMLHttpRequest to the server in a different domain. For details about CORS, see Access Control.
The CORS plug-in provides the capabilities of specifying preflight request headers and response headers and automatically creating preflight request APIs for cross-origin API access.
  If your gateway does not support this policy, contact technical support to upgrade the gateway to the latest version.
Usage Guidelines
- You have understood the Guidelines for Using Plug-ins.
 - APIs with the same request path in an API group can only be bound with the same CORS plug-in policy.
 - If you have enabled CORS for an API and have also bound the CORS plug-in to the API, the CORS plug-in will be used.
 - You cannot bind the CORS plug-in to APIs with the same request path as another API that uses the OPTIONS method.
 - When you bind a plug-in policy to an API (see Binding the Policy to APIs), ensure that the request method of the API is included in allow_methods.
Configuration Parameters
        Parameter  |
        Description  |
        Allowed Origins  |
        Access-Control-Allow-Origin response header, which specifies either a single origin, which tells browsers to allow that origin to access an API; or else — for requests without credentials — the "*" wildcard, to tell browsers to allow any origin to access the API. Separate multiple URIs using commas.  |
        Allowed Methods  |
        Access-Control-Allow-Methods response header, which specifies the HTTP methods allowed when accessing the API. Separate multiple methods using commas.  |
        Allowed Headers  |
        Access-Control-Allow-Headers response header, which specifies request headers that can be used when making an XMLHttpRequest. Separate multiple headers using commas. By default, simple request headers Accept, Accept-Language, Content-Language, and Content-Type (only if the value is application/x-www-form-urlencoded, multipart/form-data, or text/plain) are carried in requests. You do not need to configure these headers in this parameter.
        Exposed Headers  |
        Access-Control-Expose-Headers response header, which specifies which response headers can be contained in the response of XMLHttpRequest. Separate multiple headers using commas. By default, basic response headers Cache-Control, Content-Language, Content-Type, Expires, Last-Modified, and Pragma can be contained in the response. You do not need to configure these headers in this parameter.
        Maximum Age  |
        Access-Control-Max-Age response header, which specifies for how many seconds the results of a preflight request can be cached. No more preflight requests will be sent within the specified period.  |
        Allowed Credentials  |
        Access-Control-Allow-Credentials response header, which specifies whether XMLHttpRequest requests can carry cookies.  |
Example Script
  "allow_origin": "*",
  "allow_methods": "GET,POST,PUT",
  "allow_headers": "Content-Type,Accept,Accept-Ranges,Cache-Control",
  "expose_headers": "X-Request-Id,X-Apig-Latency",
  "max_age": 86400,
  "allow_credentials": true
