Help Center/
      API Gateway/
        Dedicated API Gateway User Guide (Paris Region)/
        Getting Started/
        Calling APIs/
      Creating a Credential and Getting Authorized
        Updated on 2023-12-20 GMT+08:00
- In the navigation pane, choose API Management > Credentials.
 - Click Create Credential and set credential information.
Table 1 Credential information Parameter
Name
Credential name. It is recommended that you enter a name based on naming rules to facilitate search.
Description about the credential.
 - Click OK.
Binding to an API
- In the APIs area, click Bind to APIs.
 - Select the environment, API group, and API created in Opening APIs, and click OK.
   Parent topic: Calling APIs
