Process Flow
The following figure shows the process of calling an API.
- Obtaining an API
 - Creating a Credential and Getting Authorized
APIs that use app authentication can only be called using credentials bound to them.
 - Adding an AppCode for Simple Authentication
API Gateway only verifies the AppCode during simple authentication.
 - Calling an API
Use an API test tool to call the API with app authentication credentials.
