Help Center/
      API Gateway/
        Dedicated API Gateway User Guide (Paris Region)/
        Service Overview/
      Specifications
        Updated on 2023-12-20 GMT+08:00
Specifications
Dedicated Gateway Specifications
Table 1 lists the specifications of dedicated gateways.
        Edition  |
        Maximum Number of Requests per Second  |
        Basic  |
        2000  |
        Professional  |
        4000  |
        Enterprise  |
        6000  |
        Platinum  |
        10,000  |
   - For dedicated gateways, you can adjust the maximum number of requests per second for each API.
 - The specifications of dedicated gateways cannot be modified.
 - The dedicated gateway specifications are tested under the following conditions:
- Protocol: HTTPS
 - Connection type: long connection
 - Concurrent requests: 100
 - Authentication mode: none
 - Size of returned data: 1 KB
 - Bandwidth: 10 MB/s
   Parent topic: Service Overview
