API Gateway Metrics
Introduction
This section describes the metrics that API Gateway reports to the Cloud Eye service. You can view metrics and alarms by using the Cloud Eye console.
Namespace
Shared gateway: SYS.APIG
Metrics
        Metric ID  |
        Metric Name  |
        Description  |
        Value Range  |
        Monitored Object and Dimension  |
        Monitoring Interval (Minute)  |
        avg_latency  |
        Average Latency  |
        Average latency of the API.  |
        ≥ 0 Unit: ms  |
        Monitored object: an API Dimension: api_id  |
        1  |
        input_throughput  |
        Incoming Traffic  |
        Incoming traffic of the API.  |
        ≥ 0 Unit: Byte, KB, MB, or GB  |
        1  |
        max_latency  |
        Maximum Latency  |
        Maximum latency of the API.  |
        ≥ 0 Unit: ms  |
        1  |
        output_throughput  |
        Outgoing Traffic  |
        Outgoing traffic of the API.  |
        1  |
        req_count  |
        Requests  |
        Number of times that the API has been called.  |
        ≥ 0  |
        1  |
        req_count_2xx  |
        2xx Responses  |
        Number of times that the API returns a 2xx response.  |
        ≥ 0  |
        1  |
        req_count_4xx  |
        4xx Errors  |
        Number of times that the API returns a 4xx error.  |
        ≥ 0  |
        1  |
        req_count_5xx  |
        5xx Errors  |
        Number of times that the API returns a 5xx error.  |
        ≥ 0  |
        1  |
        req_count_error  |
        Total Errors  |
        Total number of errors returned by the API.  |
        ≥ 0  |
        1  |
Dimension
        Key  |
        Value  |
        api_id  |
        API  |
