Help Center/
      API Gateway/
        User Guide (Paris Region)/
        API Opening/
        VPC Channel Management/
      Deleting a VPC Channel
        Updated on 2022-02-21 GMT+08:00
You can delete VPC channels you no longer require.
   VPC channels that are currently in use by published APIs cannot be deleted.
You have created a VPC channel.
 - Click
 in the upper left corner and choose API Gateway. - In the navigation pane, choose API Publishing > VPC Channels.
 - Delete a VPC channel. You can use one of the following methods:
- In the Operation column of the VPC channel you want to delete, click Delete.
 - Click the name of the target VPC channel, and click Delete in the upper right corner of the displayed VPC channel details page.
 - Click Yes.
   Parent topic: VPC Channel Management
