Cloud Data Center
DataArts Fabric
Cloud Transformation
Cloud Adoption Framework
Well-Architected Framework
CloudDevice
Cloud Container Instance (CCI)
Industry Video Management Service
Huawei Cloud Astro Canvas
Huawei Cloud Astro Zero
CodeArts Governance
unix_timestamp
Updated on 2025-01-22 GMT+08:00
This function is used to convert a date value to a numeric date value in UNIX format.
The function returns the first ten digits of the timestamp in normal UNIX format.
Syntax
unix_timestamp(string timestamp, string pattern)
Parameters
Table 1 Parameters
Mandatory
Type
timestamp
No
DATE or STRING
Date to be converted
The following formats are supported:
  • yyyy-mm-dd
  • yyyy-mm-dd hh:mi:ss
  • yyyy-mm-dd hh:mi:ss.ff3
pattern
No
STRING
Format to be converted
If this parameter is left blank, the default format yyyy-MM-dd hh:mm:ss is used.
The value is a combination of the time unit (year, month, day, hour, minute, and second) and any character.
  • yyyy indicates the year.
  • MM indicates the month.
  • dd indicates the day.
  • hh indicates the hour.
  • mi indicates the minute.
  • ss indicates the second.
Return Values
The return value is of the BIGINT type.
  • If the value of timestamp is NULL, NULL is returned.
  • If both timestamp and pattern are left blank, the timestamp represented by the number of seconds since 1970-01-01 00:00:00 is returned.
Example Code
The value 1692149997 is returned.
select unix_timestamp('2023-08-16 09:39:57')
If the current system time is 2023-08-16 10:23:16, 1692152596 is returned.
select unix_timestamp();
The value 1692115200 (2023-08-16 00:00:00) is returned.
select unix_timestamp("2023-08-16 10:56:45", "yyyy-MM-dd");
Example table data
select timestamp1, unix_timestamp(timestamp1) as date1_unix_timestamp, timestamp2, unix_timestamp(datetime1) as date2_unix_timestamp, timestamp3, unix_timestamp(timestamp1) as date3_unix_timestamp from database_t; output:
| timestamp1| date1_unix_timestamp | timestamp2              | date2_unix_timestamp | timestamp3                                  | date3_unix_timestamp      |
| 2023-08-02 | 1690905600000           | 2023-08-02 11:09:14 | 1690945754793           | 2023-01-11 00:00:00.123456789 | 1673366400000                |
| 2023-08-03 | 1690992000000           | 2023-08-02 11:09:31 | 1690945771994           | 2023-02-11 00:00:00.123456789 | 1676044800000                |
| 2023-08-04 | 1691078400000           | 2023-08-02 11:09:41 | 1690945781270           | 2023-03-11 00:00:00.123456789 | 1678464000000                |
| 2023-08-05 | 1691164800000           | 2023-08-02 11:09:48 | 1690945788874           | 2023-04-11 00:00:00.123456789 | 1681142400000                |
| 2023-08-06 | 1691251200000           | 2023-08-02 11:09:59 | 1690945799099           | 2023-05-11 00:00:00.123456789 | 1683734400000                |
咨询盘古Doer
