Updated on 2025-01-22 GMT+08:00
trunc_numeric
This function is used to truncate the number value to a specified decimal place.
Syntax
trunc_numeric(<number>[, bigint<decimal_places>])
Parameters
Table 1 Parameters
Mandatory
Type
number
Yes
DOUBLE, BIGINT, DECIMAL, or STRING
Data to be truncated
decimal_places
No
BIGINT
The default value is 0, indicating that the decimal place at which the number is truncated.
Return Values
The return value is of the DOUBLE or DECIMAL type.
The return rules are as follows:
  • If the number value is of the DOUBLE or DECIMAL type, the corresponding type is returned.
  • If the number value is of the STRING or BIGINT type, DOUBLE is returned.
  • If the decimal_places value is not of the BIGINT type, an error is reported.
  • If the value of number is NULL, NULL is returned.
Example Code
The value 3.141 is returned.
select trunc_numeric(3.1415926, 3);
The value 3 is returned.
select trunc_numeric(3.1415926);
An error is reported.
select trunc_numeric(3.1415926, 3.1);
