Updated on 2025-01-22 GMT+08:00
replace
This function is used to replace the part in a specified string that is the same as the string old with the string new and return the result.
If the string has no same characters as the string old, str is returned.
Syntax
replace(string <str>, string <old>, string <new>)
Parameters
Table 1 Parameters
Mandatory
Type
str
Yes
STRING
String to be replaced
old
Yes
STRING
String to be compared
new
Yes
STRING
String after replacement
Return Values
The return value is of the STRING type.
If the value of any input parameter is NULL, NULL is returned.
Example Code
The value AA123AA is returned.
select replace('abc123abc','abc','AA');
The value NULL is returned.
select replace('abc123abc',null,'AA');
