Updated on 2025-01-22 GMT+08:00
levenshtein
This function is used to returns the Levenshtein distance between two strings, for example, levenshtein('kitten','sitting') = 3.
Levenshtein distance is a type of edit distance. It indicates the minimum number of edit operations required to convert one string into another.
Syntax
levenshtein(string A, string B)
Parameters
Table 1 Parameter
Mandatory
Type
A, B
Yes
STRING
String to be entered for calculating the Levenshtein distance
Return Values
The return value is of the INT type.
Example Code
The value 3 is returned.
SELECT levenshtein('kitten','sitting');
