keyvalue
Updated on 2025-01-22 GMT+08:00
This function is used to split str by split1, convert each group into a key-value pair by split2, and return the value corresponding to the key.
Syntax
keyvalue(string <str>,[string <split1>,string <split2>,] string <key>)
Parameters
Table 1 Parameters
Mandatory
Type
str
Yes
STRING
String to be split
split1, split2
No
STRING
Strings used as separators to split the source string. If these two separators are not specified in the expression, the default values are ; for split1 and : for split2. If there are multiple occurrences of split2 within a string that has been split by split1, the result is undefined.
key
No
BIGINT
The corresponding value when the string is split using split1 and split2.
Return Values
The return value is of the STRING type.
  • If the value of split1 or split2 is NULL, NULL is returned.
  • If the value of str or key is NULL or no matching key is found, NULL is returned.
  • If multiple key-value pairs are matched, the value corresponding to the first matched key is returned.
Example Code
The value 2 is returned.
select keyvalue('a:1;b:2', 'b');
select keyvalue("\;abc:1\;def:2","\;",":","def");
