degrees
Updated on 2025-01-22 GMT+08:00
This function is used to calculate the angle corresponding to the returned radian.
Syntax
degrees(DOUBLE a)
Parameters
Table 1 Parameter
Mandatory
Type
a
Yes
DOUBLE, BIGINT, DECIMAL, or STRING
The value can be a float, integer, or string.
If the value is not of the DOUBLE type, the system will implicitly convert it to the DOUBLE type for calculation.
Return Values
The return value is of the DOUBLE type.
If the value of a is NULL, NULL is returned.
Example Code
The value 90.0 is returned.
select degrees(1.5707963267948966);
The value 0 is returned.
select degrees(0);
The value NULL is returned.
select degrees(null);
