Updated on 2025-10-27 GMT+08:00
Syntax Supported by Indexes
A large model index is used to identify or locate the position or number of a prompt or response content in the JSONPath of the request body. It complies with the JSONPath syntax. If your enable Injection Detection, Compliance Check, and Response Compliance Check are enabled, you need to configure indexes to facilitate the searching, accessing, and processing of prompt or response content.
The following indexes need to be configured for AI model checks:
  • Prompt Index: If Injection Detection and Compliance Check are enabled, this index is used to locate the position of the prompt in the JSONPath of the request body. All syntax in the following table is supported.
  • Response Content Index: If Response Compliance Check is enabled, this index is used to locate the response content in the JSONPath of the response body. Syntax 1, 2, 3, and 5 in the following table are supported. Wildcard extraction is not supported.
Table 1 Prompt and response content index example
No.
JSON structure
Path (Max. Depth: 10 Levels)
Result
Single object
{"prompt": {"role": "user","content": "..."}}
$.prompt.content
Periods (.) are used to access subnodes layer by layer to locate the target field. Each subnode name in the path must be explicitly specified.
2
Obtaining the first element
{"prompt": [{"role": "user","content": "A"}, {"role":"assistant", "content": "B"}]}
$.prompt[0].content
"A"
The array index starts from 0. [0] indicates the first element.
3
Obtaining the last element
$.prompt[-1].content
["B"]
The negative index -1 is used to indicate the last element.
4
Obtaining elements using the wildcard character
{"prompt": [{"role": "user","content": "A"}, {"role":"assistant", "content": "B"},{"role": "user", "content": "C"}]}
$.prompt[*].content
["A", "B", "C"]
[*] matches all elements in an array. Recursive retrieval is not supported.
5
Obtaining the root node
{"prompt":[{"role": "user","content": "A"},{"role":"assistant","content":"B"}]}
The JSON content of the root node is obtained.
