Updated on 2025-07-04 GMT+08:00
Usage Constraints
  • If you add your website to WAF in Dedicated mode, make sure all dedicated engines have been upgraded to the latest version, or there will be some exceptions.
    • Versions later than 202109 do not support Request Body for Field in conditions.
    • Versions later than 202303 support the Gray release mode.
    • Versions later than 202405 support JS Challenge.
  • In Cloud mode - Load balancer access mode, Response Code for Field in conditions and the Grays release mode are not supported.
