Updated on 2025-10-27 GMT+08:00
Deep Inspection
Assume that you set Field in the condition list to one of the following:
  • Path: Content supports Case-Sensitive.
  • User Agent: Content supports Case-Sensitive.
  • Params: Content supports Case-Sensitive.
  • Cookie: Content supports Case-Sensitive.
  • Header: Subfield supports Case-Sensitive, and Content also supports Case-Sensitive.
If you enable Deep Inspection, the Subfield and Content will be decoded and matched conditions in a case-insensitive manner. Deep Inspection supports Base64 decoding.
