Request Aggregation
This parameter is not required when you select Destination and By rule for Rate Limit Mode.
This function is disabled by default. Keep this function enabled so that requests to all domain names that match a protected wildcard domain are counted for triggering this rule.
For example, if you added *.a.com to WAF, requests to all matched domain names such as b.a.com and c.a.com are counted.
