Updated on 2025-07-04 GMT+08:00
Usage Constraints
  • If you add your website to WAF in dedicated mode, make sure all dedicated engines have been upgraded to the latest version, or there will be some exceptions.
    • Versions later than 202303 support the Gray release mode.
    • Versions later than 202405 support protective action JS Challenge.
  • All WAF instances: The dedicated mode does not support global request counting for WAF instances.
  • All WAF instances, Destination for Rate Limit Mode, Response code for Field, and Gray release: Those parameters are not supported if you use Cloud Mode - Load balancer access mode.
