Help Center/
Web Application Firewall/
Drawer/
Adding a Protected Object (Dedicated Mode)/
Protected Port
Updated on 2025-07-04 GMT+08:00
Protected Port
The service port corresponding to the website you want to protect. For example, if you want to protect http://www.example.com: 8080, select 8080 for Protected Port.
- Standard ports
- 80: default port when the client protocol is HTTP
- 443: default port when the client protocol is HTTPS
- Non-standard ports
Ports other than ports 80 and 443. For details, see Ports Supported by WAF.
