Updated on 2023-10-09 GMT+08:00
NTP Server Address
If you want to add NTP server addresses for a subnet, you can specify NTP Server Address. The IP addresses are added in addition to the default NTP server addresses.
  • If you add or change the NTP server addresses of a subnet, you need to renew the DHCP lease for or restart all the ECSs in the subnet to apply the changes.
  • If the NTP server addresses have been cleared out, restarting the ECSs will not help. You must renew the DHCP lease for all ECSs to make the change take effect immediately.
