Updated on 2026-01-23 GMT+08:00
DNS Server Address
  • Huawei Cloud DNS server addresses are entered by default. The DNS servers can resolve both public and private domain names.
    You can configure private zones to enable ECSs in a VPC to access each other using private domain names. Additionally, you can use the private DNS servers to directly access the private IP addresses of cloud services, such as OBS and SMN. Compared with the access through the Internet, this access features high performance and low latency.
  • If you want to use other public DNS servers for resolution, you can change the default DNS server addresses. If you use other public DNS servers, private domain name resolution is unavailable.
    You can also click Reset on the right of this parameter DNS Server Address to restore the DNS server addresses to the default value.
    Learn more about how changing VPC subnet DNS server addresses affects ECS configurations and takes effect.
FAQ
