Updated on 2025-07-28 GMT+08:00
Mounting Storage
Adding more storage enhances data access speed.
When you create a training job in ModelArts, you can choose any of the storage mount options below. The table below shows different storage choices for easy selection based on your needs.
Storage Type
Performance
Capacity
Price
SFS Turbo
High
Large
This is suitable for AI training, AIGC, autonomous driving, rendering, EDA simulation, and enterprise NAS applications.
Relatively high
SFS 3.0 Capacity-Oriented
Medium
Large
This is suitable for a variety of scenarios, including HPC, media processing, file sharing, content management, and web services.
Moderate
Parallel File System
Low
Large (scalable)
Using OBS to decouple storage from compute in big data scenarios
Relatively low
Summary
  • Choose PFS for high-capacity storage on a tight budget.
  • Choose SFS 3.0 Capacity-Oriented for better cost-effectiveness and larger storage.
  • Choose SFS Turbo for better performance if your budget allows.
