CPU Architecture
CPU architecture of the resource type, which can be x86 or Arm. Select the CPU architecture based on the required flavors. If GPUs are used, select x86. If NPUs are used, select Arm. The flavors vary by region. The actual flavors are displayed on the console.
If no flavor is available, contact Huawei Cloud technical support.
