Help Center/ ModelArts/ Drawer/ Workflow/ Subscription Notification
Updated on 2024-12-31 GMT+08:00
Simple Message Notification (SMN) can be enabled for workflows. After you select the status to be monitored from the event list, you will be notified when an event occurs. To subscribe to notifications, enable Subscription Notification.
  • After you enable Subscription Notification, specify an SMN topic. Otherwise, create an SMN topic on the SMN management console.
  • You can subscribe to events for a single phase or multiple phases in a workflow, or for workflow statuses. In the subscription list, a row indicates the subscription for a phase or an entire workflow. To obtain notifications for status changes of multiple phases, add one subscription for each phase.
  • You can select multiple subscription events for each subscription object, including Awaiting input, Executed, and Abnormal. When an event occurs, the user receives the corresponding notification.
