API Configuration
Parameter |
Mandatory |
Type |
Description |
url |
No |
String |
Request path. The default value is /. For a custom image model, set this parameter to the actual request path exposed in the image. For a non-custom image model, the value of url can only be /. |
method |
No |
String |
Request method. The default value is POST. |
request |
No |
Object |
Request body. It contains two parameters:
response |
No |
Object |
Response body. It contains two parameters:
Code example of API parameters
[{ "url": "/", "method": "post", "request": { "Content-type": "multipart/form-data", "data": { "type": "object", "properties": { "images": { "type": "file" } } } }, "response": { "Content-type": "applicaton/json", "data": { "type": "object", "properties": { "mnist_result": { "type": "array", "item": [ { "type": "string" } ] } } } } }]
