Updated on 2024-12-31 GMT+08:00
Conversion Input Path
OBS path for storing the model to be converted. The requirements for the model input path vary according to the framework.
- Caffe
For Caffe-based models, the input path must comply with the following specifications during model conversion:
| |---xxxx.caffemodel Mandatory. Model parameter file. Only one such file can exist in the input path. |---xxxx.prototxt Mandatory. Model network file. Only one such file can exist in the input path. |---insert_op_conf.cfg Optional. Insertion operator configuration file. Only one such file can exist in the input path. |---plugin Optional. Custom operator directory. Only one such plugin folder can exist in the input path. Only custom operators developed based on Tensor Engine (TE) are supported.
- TensorFlow
For TensorFlow-based models, the input path must comply with the following specifications during model conversion:
| |---saved_model.pb Mandatory. Model network file. Only one such file can exist in the input path. The model must be in frozen_graph or saved_model format. |---variables Name of a fixed sub-directory, which contains the weight and deviation rate of the model. It is mandatory for the saved_model format and optional for the frozen_graph format. |---variables.index Mandatory |---variables.data-00000-of-00001 Mandatory |---insert_op_conf.cfg Optional. Insertion operator configuration file. Only one such file can exist in the input path. |---plugin Optional. Custom operator directory. Only one such plugin folder can exist in the input path. Only custom operators developed based on Tensor Engine (TE) are supported.
