Disk Specifications
Disks with different specifications provide difference performance. Major disk performance metrics include:
- IOPS: the number of read/write operations performed by an EVS disk per second
- Throughput: the amount of data read from and written to an EVS disk per second
- Read/Write I/O latency: the minimum interval between two consecutive read/write operations on an EVS disk
You can choose whichever disk type is the best fit for your applications. If your existing disks no longer meet your performance requirements, you can change the disk type to upgrade the disk performance.
a: The maximum IOPS, maximum throughput, and burst IOPS limit all include both the read and write operations. So, maximum IOPS = read IOPS + write IOPS.
b: Take Ultra-high I/O for example: The baseline throughput is 120 MiB/s. The throughput increases by 0.5 MiB/s for every one GiB added until it reaches the maximum throughput 350 MiB/s.
c: Take Ultra-high I/O for example: The baseline IOPS is 1,800. The IOPS increases by 50 for every one GiB added until it reaches the maximum IOPS 50,000.
d: Single queue refers to performance when the queue depth or concurrency is 1. The single-queue access latency is the I/O latency when all I/O requests are processed sequentially. The values in the table are calculated with 4 KiB data blocks.
e: This API name is the value of the volume_type parameter in the EVS API. It does not represent the type of the underlying hardware device.
f: High I/O disks (except for those created in dedicated storage pools) are HDD-backed disks. They are suitable for applications with commonly accessed workloads. The baseline throughput of a high I/O disk is 40 MiB/s per TiB, and the maximum throughput of a high I/O disk is 150 MiB/s. If your applications have high workloads, it is recommended that you choose SSD-backed disks which have higher specifications.
