Updated on 2026-06-04 GMT+08:00
Weak Passwords
  • Weak passwords
    • A COMMON-PV password is considered to be weak (or invalid) if it meets any of the following conditions:
      • It has less than 6 or more than 32 characters.
      • The password contains fewer than three types of characters. For details about supported characters, see Table 1.
      • The password contains invalid characters, that is, characters that are not listed in Table 1.
      • The password contains more than two consecutive identical characters.
      • The password is defined in the weak password list.
      • The password is defined in the PV root weak password list.
    • An ECS-PV password is considered to be weak (or invalid) if it meets any of the following conditions:
      • It has less than 8 or more than 26 characters.
      • The password contains fewer than four types of characters. For details about supported characters, see Table 1.
      • The username is the same as the password or the password spelled backwards.
  • Password complexity requirements
    The password complexity requirements for ECSs apply to two scenarios: ECS creation and password reset.
    Table 1 Password complexity requirements
    Password Complexity Requirements
    ECS Creation
    Password Reset
    Length
    Must contain 8 to 26 characters. For specific requirements on the password length, see the information displayed on the console.
    Characters
    Must contain at least three of the supported four character types.
    Security
    • Cannot contain the username or the username spelled backwards.
    • Cannot contain more than two consecutive characters in the same sequence as they appear in the username. (This requirement applies only to Windows ECSs.)
    Other
    None
    Cannot start with a slash (/) for Windows ECSs.
    Supported characters
    Uppercase letters
    Uppercase letters
    Lowercase letters
    Lowercase letters
    Digits
    Digits
    • Special characters for Linux ECSs: !@$%^-_=+[{}]:,./?~#*
    • Special characters for Windows ECSs: !@$%^-_=+[{()}]:,./?~#*
    • Online password reset:
      @%-_=+[]:./^,{}? (only applied to Linux)
      $@%-_=+[]:./,? (only applied to Windows)
    • Offline password reset:
      Special characters for Linux ECSs: !@%-_=+[]:./?
      Special characters for Windows ECSs: !@%-_=+[]:./?
