Flavor Name of a Layer-7 Load Balancer
It specifies the flavor name of a Layer-7 dedicated load balancer that is created automatically. You can obtain the flavor list to learn which types are supported.
- Elastic: suitable for fluctuating traffic, billed based on total traffic. Clusters v1.21.10-r10, v1.23.8-r10, v1.25.3-r10, and later versions support elastic specifications.
- Fixed: suitable for stable traffic, billed based on specifications.
This parameter is available only for dedicated load balancers. The value of this parameter must be the same as that of l4_flavor_name, both of which are elastic flavors or fixed flavors.
Value Range
None
Default Value
None
Modifiable
Yes
Scope
CCE standard and CCE Turbo clusters
