Updated on 2025-06-13 GMT+08:00
Layer-7 Load Balancer ID
It specifies the ID of a Layer-7 dedicated load balancer that is created automatically. It has the same function as l7_flavor_name and specifies the flavor of a load balancer. Configure either of these parameters. If l7_flavor_name and l7_flavor_id are both configured, the value of l7_flavor_name is used.
Value Range
None
Default Value
None
Modifiable
Yes
Scope
CCE standard and CCE Turbo clusters
