Updated on 2025-06-13 GMT+08:00
Subnet Where the Load Balancer Backend Server Is Located
It specifies the subnet where the backend server of the load balancer is located. If it is left blank, the default cluster subnet is used. Load balancers occupy different number of subnet IP addresses based on their specifications. Do not use the CIDR blocks of other resources (such as clusters and nodes) as the load balancer CIDR block.
This parameter is only available for dedicated load balancers.
Value Range
All subnets in the cluster VPC
Default Value
Subnet the cluster belongs to
Modifiable
Yes
Scope
CCE standard and CCE Turbo clusters
