Updated on 2025-06-13 GMT+08:00
Port for a Health Check
It specifies the re-specified port for a health check. If it is not specified, the service port is used by default.
Value Range
None
Default Value
None
Modifiable
Yes
Scope
CCE standard and CCE Turbo clusters
Suggestions
Ensure that the port on the node where the pod is located is in the listening state, or the health check will be affected.
