Updated on 2025-11-11 GMT+08:00
Pod Security Group
It specifies the security groups for a pod running on a node in a node pool. You can set the parameter to the security group ID. It works with the security group policy on the workload details page to manage pod access in a cluster.
Security groups cannot be specified for node pools created using the console. Security groups can only be configured in the node pool configuration management after the node pool is created.
Value Range
UUIDs. A maximum of five UUIDs can be configured.
Each UUID must be unique.
Default Value
Null
Modifiable
Yes
Scope
CCE Turbo clusters
The configuration is applied through the configuration management of yangtse-agent.
