Help Center/
Cloud Container Engine/
Drawer/
Configuration Reference/
Node Pools/
Container Engine Settings/
Maximum Size of the core File in a Container
Updated on 2025-11-11 GMT+08:00
It limits the core file size in a container.
Value Range
Greater than 0
Default Value
5368709120
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Configure this parameter based on the specific scenario. Typically, the default value is used.
