Updated on 2025-11-11 GMT+08:00
Maximum Data Space per Container
It specifies the maximum data space for a container. It is only supported by device mapper frameworks and does not support OverlayFS.
Value Range
Greater than or equal to 0
Default Value
0
Modifiable
No. This parameter can only be configured during initialization.
Scope
CCE standard and Turbo clusters
Suggestions
Configure this parameter based on the specific scenario. Typically, the default value is used.
