Help Center/ Cloud Container Engine/ Drawer/ Configuration Reference/ Node Pools/ Node Network/ Custom Security Groups Associated with a Node
Updated on 2025-06-13 GMT+08:00
It specifies a custom security group configuration for a node pool. After a custom security group is configured, the default security group of the cluster will not be used for new nodes.
Modifications to custom security groups will not automatically be applied to existing nodes.
Value Range
UUIDs. A maximum of five UUIDs can be configured.
Each UUID must be unique.
Default Value
Null
Modifiable
Yes
Scope
CCE Turbo clusters
Security groups are disabled by default in some regions. In this case, the request body can be empty when the custom security group list is transferred to servers.
