Node Pool Auto Scaling
After auto scaling is enabled for a node pool, autoscaler will add or delete nodes in a node pool based on rules such as the maximum and minimum number of nodes, scale-in cooldown period, scaling priorities, and auto scaling scenarios. autoscaler parses and selects the auto scaling policies for the clients.
The configuration is not applied until after auto scaling is enabled.
Value Range
true or false
Default Value
false
Modifiable
Yes
Scope
CCE standard and CCE Turbo clusters
Node pool auto scaling configured directly using the CCE console or APIs is not restricted by related parameters.
