Node Pool Name
Five random digits are added to the end of the names of nodes created in a node pool. For example, if the node pool is named nodepool, a node created in that pool will have a name like nodepool-47bl2.
Value Range
Naming rules:
- Enter 1 to 50 characters starting with a lowercase letter and not ending with a hyphen (-). Only lowercase letters, digits, and hyphens (-) are allowed.
- You cannot create node pools named DefaultPool.
- Node pool names must be unique within a given cluster.
Default Value
{Cluster name}-{5-random digits}
Modifiable
Yes, but the node pool name must be unique within the cluster.
Scope
CCE standard and Turbo clusters
