Help Center/ Cloud Container Engine/ Drawer/ Configuration Reference/ Nodes/ Compute Settings/ Node Type
Updated on 2025-11-11 GMT+08:00
Node Type
Options for a CCE standard cluster:
- Elastic Cloud Server (VM): Containers run on ECSs.
- Elastic Cloud Server (physical machine): Containers run on servers using the QingTian architecture.
- BMS: Containers run on BMSs that have local disks or EVS disks attached.
Options for a CCE Turbo cluster:
- Elastic Cloud Server (VM): Containers run on ECSs. Only ECSs that can have multiple network interfaces attached are supported.
Value Range
None
Default Value
None
Modifiable
Yes
Scope
CCE standard and Turbo clusters
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
