Minimum Connection Tracking Entries
It specifies the minimum number of connection tracking entries that can be reserved in a Linux conntrack table. It guarantees that the system maintains a fixed number of connection tracking entries at all times, even when the actual number of connections is low. This prevents performance overhead associated with dynamically allocating or releasing resources.
Value Range
Greater than or equal to 0
Default Value
131072
Modifiable
Yes
Scope
CCE standard and Turbo clusters
Suggestions
Do not configure this parameter.
