Updated on 2025-06-13 GMT+08:00
Flavor Name of a Layer-4 Load Balancer
It specifies the flavor name of a Layer-4 dedicated load balancer that is created automatically. You can obtain the flavor list to learn which types are supported.
  • Elastic: suitable for fluctuating traffic, billed based on total traffic. Clusters v1.21.10-r10, v1.23.8-r10, v1.25.3-r10, and later versions support elastic specifications.
  • Fixed: suitable for stable traffic, billed based on specifications.
This parameter is only available for dedicated load balancers.
Value Range
None
Default Value
None
Modifiable
Yes
Scope
CCE standard and CCE Turbo clusters
