Updated on 2025-11-11 GMT+08:00
EIP IPv6 Bandwidth ID
It specifies the IPv6 bandwidth ID of the EIP bound to a dedicated load balancer and the ID of the bandwidth used by an IPv6 address. It is only available when you create or update a load balancer with a public IPv6 address. If you bind a new EIP to the load balancer and specify a shared bandwidth, this EIP will be added to the shared bandwidth.
Value Range
None
Default Value
None
Modifiable
Yes
Scope
CCE standard and Turbo clusters
